Hellcat Boost Access Port
Chuckbizkits
North Orange County, CA
I'm running a mechanical boost gauge. Outside of taking the SC apart, drilling and tapping, is there and access port or aftermarket part to attach the line?
i have NO idea, but the pressure you are looking for is basically manifold pressure, so a simple T in any manifold vacuum line should do the trick
should
i think
Need boost access, not vacuum.
two sides of the same coin
have you looked at a boost gauge recently?
now, i could be wrong, but any air in the intake tract past the supercharger will be under boost if you're on the fun pedal, or under vacuum
Yup. My gauges show both. However, while boost effects vacuum, they are not the same. You can gave zero vacuum and 7 lbs of boost.
absolutely, but you can not have boost and vacuum at the same time
kinda like a thermometer, it can be freezing, or it can be 80 degrees out...but not at the same time
if i understand it correctly, engine vacuum is created by the pistons going down, sucking in air that isnt there since the throttle body is closed
boost is made when the supercharger tries to force more air than the piston can suck in going down
what is the common element here?
the intake tract between the top of the piston and the supercharger
now, like i said i could be wrong, but i dont think i am (not that it would be the first time)
it is easy enough to verify though, if you can get the engine to create boost while in neutral just pop of a vacuum line and see if it has boost or not
is the hello kitty engine intercooled?
if so, find a metal part of the intercooler and tap it for a nipple
now, if you want to just throw money at it and be done with it, order yourself one of these
Boost Reference Adapter by TBA Machine
(on a side note, look at what that adapter tells you you can find there...boost and vacuum)
That's it! It is intercooled but with liquid.
