hello all just bought a.....
gniknayrb18
san angelo, tx
hello i just bought my first mopar restoration project a 1972 dodge demon ill post some pics here in a few and im going to be needing as much help as i can get thanks for looking.
here you go
i am new to mopar muscle just not new to mopar....04 1-ton dually and 09 caliber for the wife.... i might need some advice with a rear end..,, ok my demon originally came with a slant 6 and 3 speed with a 7 1/4 rear end and now the demon has the 340 from a 71 and a 727 with the same rear end....i have a guy here that has an 8 3/4 rear end but its been modified so you can put slicks on it....very short axle and long spindles am i gonna have any problems bolting that in and the tires have to be about 1 ft across so am i gonna have to cut the inner fenders
Welcome.FABO has a good used parts for sale section.Check it out.
those might be the actual buckets... you would get new seat foams & replacement vinyls from Legendary if that is the case.
just getting a set of frames for them can be costly. i've seen unrestored pairs of buckets going for $800+ or even $1000
http://www.legendaryautointeriors.com/
It is not the correct bucket seats. they are from a 73 or newer as you can tell by the seat cover only difference from earlier ones is the foam and cover but frames and tracks are the same. Only tracks that are different are the inner driver side track on 75 and 76 A bodies because of the catalytic convertor
see i was told that the 71 had the foam like your talking about but the 72 they changed the sets to these is there any truth to that
The only difference is the covers for 70-72 but 73-76 have different covers and foam from 70-72
The ones currently installed in your car are from a 73-76 A body.
You can use your current seat frames and tracks and just get new foam and covers for a 72 Demon and you will be ready to go
