what is the initial timing in gear? if it's not 15 deg BTDC @ 800 RPM it's not enough.in gear.
The top hole is where it should be. Closest to the carburetor, right?I tried moving to the middle hole from the top hole with no success. Put back in top hole.
It has to be disassembled. There are slots in the distributor governor. The length of those slots determine how much mechanical advance the distributor has. The old racers trick is to weld those slots up a little and file them to a specific shorter length, so that the distributor only advance as much as you need. I have a hot slant 6 in my 64 Valiant, for example. SLant sixes don't need anymore than about 30-32 degrees total timing. I run mine with about 22 initial timing at idle. I shortened the governor slots up in the distributor to provide about five distributor degrees, which is about 10 at the crank for a total of 32.Ill advance it to about 10* BTDC and see what happens. Not sure I understand how to limit the dizzy.
I GUESS you could, but that would be a major PITA. Plus, you could easily drop something into the distributor with it being way in the back. Just pull it.Can the dizzy be disassembled to that point still mounted on the engine? I also want to verify the mark on the balancer.
Just scroll down some.Where do you get the limiter plate from?
Just for kicks, check the firing order. 1-8-4-3-6-5-7-2. I forget which two but there are two that can get crossed and make it run rough and not pop or backfire. I THINK it's 6&8 but I wouldn't sweat to it.I have actually been running about 15* all along and didn't know until the exercise I went through today to fine #1 TDC. I bumped it about 17-18 and tried it and no change. Still rough comes in about 1600. I tried more jet and metering rod changes with no help. I almost to the point to jet me another carburetor. Is there anything else in the ignition system that could cause this?
Those 1407s are a known issue. I had one I went through multiple times and couldn't do anything with it. It had issues with running way to rich. Nothing I could do changed it.Good thing to check, I hadn't thought of it. Just checked and the firing order on the dizzy is correct. Thanks everyone for their input and ideas. Keep em coming. I think I'm going to buy a carburetor.
