help decode my fender tag, 72 swinger
discharger1332
silverdale wa.
i rencently acquired a 72 swinger, it seems to have a lot of options and a very short fender tag. I am thinking some were added? any help is appreciated.
Here is a link to a decoder:
Mopar Fender Tag Decoder
Code
Description
E24
225 1 Barrel 6 Cyllinder
D34 TorqueFlite Automatic Transmission
LH23
L
= Dodge Dart / Demon
H = High
23 = 2 Door Hardtop
C2R
C
= 225 110HP(net) 1-1BBL 6 CYL
2 = 1972
R = Windsor, ONT, CAN
353695 Sequence Number '353695'
GF7 Paint Code: Dark Green Metallic
F3F6
Trim Grade/Style/Color
F = F Class
3 = Cloth and Vinyl Split Bench w/ Center Armrest
F6 = Green
GF7 Upper Door Frame: Dark Green Metallic
701 Date Built: 7 / 01 / 1972
304376 Order Number: 304376
V1F Roof Type OR Color: Full Vinyl Top - Green
U Built to Specifications for USA Order
B51 Power Assisted Brakes
C12 Shoulder Belts
G33 Left Hand Outside Mirror - Manual / Chrome
L31 Hood / Fender Mount Turn Signal
M21 Roof Drip Rail Moldings
M88 Quater Panel Tape Treatment
R11 Music Master Radio AM
V5X Black - Mouldings - Protective Insert Body Side
END End of Codes
would options like rear defrost or 3 speed wipers be on the fender tag?
Thank you by the way, everything listed is correct.
what is the m88 i wonder?
M88 is the molding on the deck lid and quarter panel extensions. No, the 3 speed wipers will be on the broadcast sheet along with the rear defrost as these are not external options like moldings and mirrors, etc.
What was coded varied by plant. J25 will not be on the tag not because of internal/external issues. It's simply that the Windsor plant did not code J25 on the tag for model year 1972. The Hamtramck plant did code it; the Windsor plant didn't.
Do you have a photo of the door VIN label? Some later '72 models got the newer style label with the MDH code, so I am just curious.
This is where the online decoders fail -
Per the MDH code (Month Day Hour) on your door sticker, the car was built earlier than 'hoped for' per the SPD (scheduled production date) on the fender tag.
Your MDH of 062813 is June 28, 13th hour of the day.
