help- do i have 9 or 10 inch drums, and what about shoes???
cullenc101684
Member
Portsmouth, VA
I have no idea if i need 9 or 10 inch drums, when going about 40plus and i hit the brakes the steering wheel shakes very similiar to when you need new rotors on a disc brake car. Im not familiar at all with drum brakes, so do i order 9 or 10 inch drums and do i need to order new shoes as well? any help is appreciated. my car is the stock 5 x 4 bolt pattern. Thank you.
take the wheel off. unscrew the hubnut. take the hub off. grab a tape measure and measure it across the inside of the hub. if you still cant figure it. go to your local parts dealer and they can help you out.
We cant help you out with no info on your car. What model is it? what year is it? what motor? need info
