So My longblock is an early 70's 360 .030 over. compression at zero deck with eddy heads is at 11.9-1 260/266 duration and .558/.555 list solid cam.
trans is 727 with full manual reverse valve body pro bullet proof build 3500 stall convertor
rear is an 8 3/4 with 4.10's
need suggestions on finishing the top end or swapping heads and the rest of the build.
how well do you think she will run and hp/torque estimates
