DartSportDude
Old school A-body owner
Recently, I had the original 340 engine in my '73 Dart Sport rebuilt by a local machine shop. It's a long story, but this was an original engine (in very good running condition) that had suddenly started smoking like crazy after I'd had a repair shop do some work on the car (they replaced the rear main seal and valve cover gaskets). The engine had NEVER smoked before this work was done. I was told the engine had a bad ring, and thus it went in for a rebuild (to a different shop that came highly recommended).
After I got the Dart back following the rebuild, I started the normal break-in process and everything appeared fine for the first 100 miles or so. Then, I started to notice a slight plume of blue smoke from the driver's side tailpipe at cold start-up (this was after the engine kicked down following a minute or two of high idle). I just assumed this was normal for a rebuilt engine. However, the blue smoke became more pronounced over several startups, so I took the car back to the shop that had re-installed the engine for me (not the machine shop that did the rebuild itself).
Anyway, the repair shop says the blue smoke has diminished since they've had the car (four days), and that such smoking is just a normal part of the engine break in. They said I should just drive the car more and see how it goes.
Does this sound right?? The engine did not smoke at all when I first brought it home; why would it be starting now? I'm afraid the shop is just reluctant to tear into the engine to diagnose the problem.
Should I be worried? Thanks for your help.
