Help ID these shift rods
cudascott
It’s a sickness!
TN
Does anyone recognize any of these shifter linkage rods?
From left to right I think 2 and 3 are 1-2 and 3-4 O.D
rods but don’t have a clue about the others.
My best guess is from left to right number 2 is the 1-2 A body shift rod and number 3 is the 3-4 A body shift rod. You can tell those by the way the adjuster end is bent to make the rods clear the transmission cross member mount (whatever the technical name is for the frame member the crossmember bolts to) as they have to go up to miss it.
The other ones I have no clue.
