273's were never smog motors. We actually had to put 318 open chamber heads on my brothers 67 Cuda to be able to run gas less than premium. You guys are too obsessed with compression. It is flow that makes you go fast. Not that you want 7:1 unless you are huffing a motor, but I don't think you could get to 7:1 with any factory combination on a 273.
what psi does an engine crank at 5000 rpm...50-70 psi.[example] a lot less than cranking dynamic.
more compression keeps that # high/er, which pulls on the heads=flow
with rpms comes less time for high psi seek the low psi in the cylinder, which is how you end up going from 140 cranking psi to 50-70.[example]
what pulls and pushes harder, 50 or 70?[example]
response comes from high compression , amongst other things, thats due to stronger signal to the carb which aids fuel mixing which aids torque which is multiplied by rpm which is HP...
you want as much compression as you can reasonably get away with on the octane you have available or are limited to.
jmo
heres a good read
http://circletrack.automotive.com/11016/piston-tech-air-fuel-optimization/index.html
and a lil quip from the artical..
Sir Harry R. Ricardo made certain statements about turbulence in his academically classic High Speed Internal Combustion Engine books of the early 1900s. Among them was the following: The rate of burning depends primarily upon the degree of turbulence and may be expressed in terms of increase of pressure per degree of crank angle. This approach is currently used in the method of Engine Cycle Analysis (ECA) being employed by leading Winston Cup teams. His statement clearly defines the fact that mixture completeness (homogeneity) and burn rate are related.
Ricardo also noted that the need for turbulence decreases in proportion to an increase in mechanical compression ratio (c.r.). Stated another way, as compression ratio is lowered, the need for and benefits from mixture motion increase.
For example, gains from turbulence in a 9:1 c.r. engine gasoline will be more substantial than in one of 13:1 c.r., although some gains are possible at the higher c.r. In addition, Ricardo suggested that a turbulent vs. non- turbulent engine tends to experience detonation earlier by comparison. This provides an opportunity to remove a measure of spark timing, allowing for an increase in net cylinder pressure after TDC and subsequent gain in torque (positive vs. negative work).
