BillGrissom
Good you got the Saginaw pump. It is supposed to be a little better (more efficient) than the Federal pump. I think they used it exclusively on the FMJ cars (Aspen, Volare). I bought a Federal pump before I knew that.
I am switching to ATF+4 for p.s. in all my cars, including the Mercedes. Chrysler has used it since 2005 and has a TSB recommending switching to it in earlier cars (like my 2002 T&C) when doing major work on the p.s. It is supposed to eliminate "cold chatter" in some pumps. They do warn to get all the old amber fluid out first, but could just be the lawyer's input, in case there is some mystical chemical reaction. I just sucked as much fluid out as I could and flushed 1/2 qt thru in my 1984 M-B recently when I had to change the h.p. hose.
