Help Identify this part...
Tjhoward84
1969 Barracuda Convertible
Bothell
Can someone help identify where I can get 10 of these "spacers"? They go on the 2 side rails that hold down the convertible top. They are for a 1969 Barracuda convertible.
intake /exhaust washer for the mounting of slant six manifolds to the engine. Lawrence
Golly, those sure do look similar! TJhoward's look to be punched, and if he has MY luck, they're punched from unobtanium! I wonder if those manifold washers are the same size (or "close enough for government work". The manifold washers are often available on ebay, but if he's wanting "correct" pieces, for a points correct show car - - well sir, good luck!
BC
can you show a picture of where they are mounted? the convert guys will confirm your spacer situation. Lawrence
Got these with an aftermarket manifold, but decided to use my original hardware. The hole is a little over 3/8" (13/32) they are about 3/16 thick and 1 3/8" across the long part. I'd like to get $15 including shipping. PM me if interested.
SOLD
I'll take them. They look exactly like the ones I need. I'll PM you.
