Help Identifying 14” Trim Rings
Musclesigns
Maryland
I picked these up a while back and have no idea what they’re from, including whether or not they are Mopar parts. Any help identifying will be appreciated. Thanks!
Look on the backside of the ring and you might find a logo or part number.
Visually, they appear similar to the ones on my 14 x 5.5 rally wheels. Brush finish, with a sharp transition from the rim to the inner surface. However, there is one difference — yours appear to have a lip on the inner edge (where you hooked your tape measure) — on mine, the sloped surface just ends. I don't know if this affects the fit.
There is another style that is polished and has a rounded transition, that you often see used with dog dish caps.
If they fit, I see no reason not to use them.
Thanks for the inputs. All my cars have 15 inch rims so just looking to see what they are. Posted on another board and someone has a similar set that are GM.
