Help Identifying 340 Valve Covers
ricks70dart
Federal Way WA.
Would these covers be 68 340 if not does someone have pictures of the correct 68 340 covers.Is there an early and late cover in 340 68? Thanks.
They look like 68 not sure what year they changed to a rubber grommet for the PCV valve I was thinking 68, 67 had the tube on both sides
I have been looking at other 68 340 covers on line.Seems some have the 4" half round wire loom retainer on the pass side to keep wires away from the hot intake? The 69 and 70 340 covers had these.Still not fully convinced these are 68 340 any help identifying these covers greatly appreciated Thanks
You are right, the 340 cover for the pass side had a heat shield for the alt, temp sensor wires.
found this picture online
The drivers side is the same only the pass side is different.
