These are the SRP piston specs: http://www.jepistons.com/Catalogs/SRP/Mopar/340-360_flat_inv.aspx
Part #142068
CID 345"
Bore 4.070"
Stroke 3.313"
Rod 6.125"
Lgth.Block 9.586"
Ht.Comp. 1.804"
Ht.Head Cubic Centimeters 65cc Compression Ratio
Dome Vol. -5cc
Compression Ratio 9.8
Gram Wt.
530
JE gets their ratio with a .040" compressed gasket thickness.
Mine will be with .050" compressed thickness gasket. I measured the fire rings in the head gasket at 4.168"
Part #142068
CID 345"
Bore 4.070"
Stroke 3.313"
Rod 6.125"
Lgth.Block 9.586"
Ht.Comp. 1.804"
Dome Vol. -5cc
Gram Wt.
