nuttyprof
I have an '80 Vloare wagon, and over the weekend I adjusted the valves on the slant 6 in it. When I took the air cleaner housing off I found a disaster, the wiring has been butchered, the vacuum hoses unplugged and left off, and the top of the carb is loose!
When I went to tighten the carb screws I discovered the holes are stripped,
so I will be replacing it when I can find one (I may have one in my assortment of "stuff") but I need diagrams for the vac and wiring. If there is someone who can point me to those online that would be a big help. Thank you.
