Help pypes sma10s exhaust
jazak5
NY
can anyone show me pictures of this exhaust system installed/ on a 69 fb barracuda/ Not sure how far back the X is to the transmission and I am having trouble with the over axle pipes afull install photo would be nice !!!!!!!!!!
Not much help but mine fit terrible on a 72 Dart. Had to modify all over the place. After the mufflers to the tailpipes was the worst. Chevy tailpipes if you ask me! Spent as much on parts and labor as the kit cost. Sorry..... and good luck!
Don't forget that Dodges generally have a longer wheelbase than Plymouths. (Dart vs. Barracuda) Don't be surprised if you need to cut 3" off the length.
Usually the X ends up somewhere under the tailshaft?
The universal pipe theory as mentioned is also a possibility. It may fit a Nova or Camaro perfectly.
Start at the tailpipes and work your way up to the engine, trim the 1 foot sections of pipe they give you to make up the difference. Also the long section of pipes that come off the X pipe are too close together and need to be spread apart or the mufflers will be too close to the driveshaft, a floor jack will work to spread the pipes, just put the jack between the pipes and give it a pump or two.
