HELP, sb magnum 360 pushrods
Dartblower
Finland, Kauhajoki
my frend have stroked 360 , 408, old block 1975.
now installing magnum rt steelheads, and have hyd.roller cam.
we have here 7.200 " long pushrods, but these are too long !
maybe it have to be 7.000" ??????????????
what is right lenght ???????????
Thanks
Can't tell you for sure, only what my experience has been.
Running R/T heads as well, with Hughes drop in roller lifters. I am running a set of SB Ford pushrods at 6.881" long, but I haven't started the motor yet. Factory pushrods for a Magnum are 6.9" long, the shorter ones I have put my preload at about .080" deep. According to Tim at Hughes, that should be about right. If it isn't, I am going to swap some 6.821" Comp pushrods in and see how that works.
Don't know enough about your setup to say what works. Just relaying what I did.
Thanks
6.91 is the length of the factory magnum pushrod.
But I would get a length checker before I guessed.
Lifter height and type will change this requirement.
