Dart_440
So I decided to go with an 8.8 for under the dart. I picked one up cheap with 3.73 limited slip and discs.
Anyway.. I took it to strange engineering this morning to have them shorten the long side axle tube. No problem they say, so I drop it off and just got a call, they say they can't do it. Now I have to drive 1 1/2 hours back to get it for nothing. UHHG
Their method is to cut the 4 bolt flange off and then shorten the tube then weld the flange back on. The problem with this is the axle tube is tapered from 3.25" dia to 2.75" dia starting at the flange out about 1 1/2", to allow access to get the 4 bolts in. So there method would cut the taper off and then the tube/weld would be going through my bolt holes.
There only suggestion is to change the ends to 9" ends.. but then I have to change everything else. Any money is not going to allow me to do that.
I need some help, I am on a tight tight budget. Who has done this and how?
I have seen some posts where the whole axle tube was removed, shortened and then pressed back in?? Strange will not do that for me. Where did you take it to get it pressed back in?? How did you align it?
Any ideas would be great..
Thanks Bryan
Thanks Bryan
