Help wiring transbrake please
vernfields jr
Ok I have a Cope racing pro trans with a 1 wire transbrake. How do I wire it thru my turbo action shifter with 2 wires thru a toggle switch for on and off.
Run 12volt to one side of switch then run wire from switch to transbrake. Solenoid on transbrake is grounded. You might want to put a fuse in line from power source
No relay toggle will be for power to the button only so I know when it's on and off
