SSG_Karg
Enhanced member
I have a Kaeser AS30 oil injected screw compressor. It will not go into load phase from idle. It will only build 25lbs of pressure in the sump with the vent line valve open and will only climb to 50lbs if I close the valve. I’m thinking the minimum pressure check valve is hanging up. Anyone know air compressors?
