Help with Decal Placement
Wyolemontwist
Member
Cheyenne, WY
I recently bought the Mopar Technical Graphics kit from Phoenix Graphixs for my 1970 Duster 340, but unfortunately they do not include a guide for decal placement. I have a general idea as to where some of these decals go, but I want to make sure I orient and place them in the correct areas as my car no longer had any of these decals on it when I bought it. Most of these are actual decals, but a couple of them are tags that are hung inside the vehicle to give the nostalgic look of a brand new car on the dealership lot. I've attached a photo and numbered each decal to make it easier when referencing a specific decal. Any help would be greatly appreciated!
#4 is 1969 & back so put it on your toolbox.
Sadly, some kits are 'off'.
10 inside middle trunk lid.....9 drivers side door jamb........ 3 inner fender well on drivers side.....1 radiator cross piece bar
Do you know if #6 is supposed to go above or below the jacking instructions? And is #1 supposed to go on the far right side (driver's side) of the radiator crosspiece bar?
If I'm not mistaken doesn't #6 go on the metal jack base itself? not sure maybe someone else will chime in.....but I believe I remember seeing them there......here is a picture of my original placement of #1 on my 73 dart sport .....this decal was used on 1969-1973 cars....It is hard to make out in my picture but it is that decal and it is about 2/3 on the radiator and 1/3 on the battery as far as right to left.....the decal next to it on the right that is smaller and toward the end is this one
[FOR SALE] - new "use genuine mopar parts decal sticker" for under hood
but this is not correct for 1970...this was on late 73 and later models
Thanks for the help guys! I know #2 is the air cleaner decal, but does anyone know where the correct placement is for it on the 1970 Duster air cleaner?
#11 is for a rebuilt engine.
#7 is not used on 1970 cars (once again' Kit fail')
not s
Me either but make sure you put it on crooked if you want it to look original. Ha
While you are at it get yourself some new battery cables. You are looking at future problems with what you have.
My air cleaner for a 67 Barracuda the air cleaner decal was front just right of center. Mine has a little flat spot you could tell that's where it goes.
Not sure how yours is painted but mine was the crinkle paint. Decal didn't want to stick so used a little super glue.
If you use glue be careful the decal is thin, you only get one chance to line it up.
#10 middle to left to middle upper third trunk lid. Read when the car came down the line no real specific place just where the guy put it on.
I placed mine left side aligned between a couple trunk frame things...you know what I mean. I put the sure grip sticker (7) right above it.
