Help with decoding buildsheet!
crazyswede
Active Member
sweden
I found most of the info i need/want but i have som issues with a few codes. First of all its the axle. Second row where it says D8 I cant seem to find what the 3 is. Could only find D81, 82, 84 and 85 :/
Also on the brakes i couldnt find the rear size code for B24 as it says on mine.
Sorry if this is the wrong section but i couldnt find a more proper one!
Thanks in advance.
Well im almost certain my car is 100% original but i would like to have it confirmed. I got an 8 3/4 rear axle on it and any help is appreciated with confirming that with my buildsheet. Seems a bit over the top with that rear end on a stock slanty but im not complaining :D also i have the 10" x 1,75" rear drums. would like to know if that to is what the sheet says it should be.
Much appreciated. As i tought then the rearend is what it came with from the factory. Without saying your wrong about the brakes are you sure about the 2 1/2"? Or could it be that the same sheetcode reads different depending on if you have large or small boltpattern?
