Help with drag shock set up
72plymouthscamp
FOOSE ME
Michigan
I have adjustable drag shocks front and rear with s/s springs. My question is what the proper set up for the shocks? Is it soft in back and hard up front or vice versa or hard all the way around?
In the rear, start in the middle, see how much body rise you get. 3" good starting point, then start dial in. Front, start about 20/80. One end at a time, as front affects rear.
You will have to do trial and error. i have my Scamp on the softest settings.
What torsion bars do you have? You want slant six bars or you can spend the money and go with the racing ones
For the strip, 50/50 rear, 90/10 front is a good starting point. YOu probably won't mess with the front much but the back may need a littl looser rebound adjustment.
