HELP With INLINE TUBE BRAKE SET!
scottylack
NEW JERSEY
got a kit from inline brake... cant figure out where each piece goes...I know where the large one goes (not shown)
its the rest of the pieces....
A is obviously the pieces that head from master
a= master cylinder to proportioning block
b= front proportioning block to rear of car with inline bias valve
c = driver side inner fender bulkhead to proportioning block
d = firewall line from proportioning block to passenger inner fender bulkhead.
they take a bit of tweaking. I installed the same kit in my car. they are pretty close just take a little bit of persuasion.
so its ok to twist a little?
will be doing this in the next month...just getting everything in order
yes you can "twist" you shouldnt have to get too carried away. they should be close. just be careful not to kink them. they are stainless it looks like so they should move without kinking.
