Help With Lunati Cam ID
Heywodja
The Heartbeat Stops Here
Texas
I started on a project 440 about 17 years ago.. It has 452 unmilled heads and TRW L2366 .30 over pistons, felpro blue gaskets which I think are .039 compressed. No milling on the block that I know of.
I installed a Lunati cam but no longer have the cam card or specs.
I can’t find any info on the cam in the innerwebz either.
I am going to pull the heads and pistons to double check the ring gaps and such. I am concerned with being over cammed.
I am attaching a pic for help with identification.
Oh hell I posted from my phone and the pic came out upside down,sorry
I searched Lunati for a 306 grind but no luck..
There's one on there with 306 advertised, but it's ground on a 108.
I'm gonna say it's a Part number 30306, that's where the 306 comes from on the stamp...
Part #: 30306
Power Band: 3000-6500 RPM
.507/.534 lift
235/245 duration @ .050"
285/295 advertised duration
Lobe Centerline: 106°/114°
Lobe sep: 110°
Overlap 70°
Open/Close @ .050"
IVO: 11
IVC: 43
EVO: 56
EVC: 8
Open/Close Advertised Duration: (*calculated)
IVO: 36.5
IVC: 68.5
EVO: 81.5
EVC: 33.5
Sounds like you nailed it krazy, and it also seems like it is not very well suited for my application..
I would do a quick map/degree of the cam to verify that it matches my guess before making any decisions...
Part #: 30306
.507/.534 lift
Lobe sep: 110°
Overlap 70°
Open/Close @ .050"
IVO: 11
IVC: 43
EVO: 56
EVC: 8
IVO: 36.5
IVC: 68.5
EVO: 81.5
EVC: 33.5
Well damn, the only thing I had correct was the LSA. I used to have a Lunati catalog but I can't find it.
I had made a master list for popular manufacturers of Mopar cams on an Excel spreadsheet back in the late 90's before they updated the grinds...
I recorded all given specs , then calculated all data back to verify... I found a few specs right from the manufacturer that were incorrect and figured out what they should have been on my sheet.... I had literally thousands of hours updating and correcting errors...
THATS IMPRESSIVE!!!!!!
Impressive is an understatement!
This forum rocks
I will call them and see what they have to say..
