If you are SURE about the pickup coil reading, I'd replace the pickup. The ohms stated varies. I would guess the variance is due to loose specs and import parts. But that far off is WAY off.
Don't know what all you have tested, here are a few:
VERY important that the ECU is GROUNDED and that you determine that, with key in "run" that the coil is drawing current. To do that do this:
Turn key to "run." Stab one probe of your multimeter, on DC volts into the top of the NEG batt post or a KNOWN good ground. Stab the other probe HARD into the case/ mounting flange of the ECU box. MAKE CERTAIN you are NOT touching the heat sink/ transistor. With key in run, your should read near 0 or 0
Again with multimeter grounded, connect the other probe to coil MINUS. Reading should be quite low, 1 or 2 volts.
Next connect to coil POSitive. REading should be (variable) 4-7V or so. If it is much lower you have a problem, and if it is full battery voltage the coil is not drawing current
Now with the key in "run" "rig" a spark test gap with the coil wire. Best to use a wire core wire. Take the engine harness half of the distributor connector and tap the exposed terminal to ground. Each time you do so should result in a snappy "SNAP" spark, just one
You can test the distributor "sort of." Connect your multimeter in low AC -- that's right -- AC volts to the connector. Crank the engine or if out of the car spin the dist. shaft. The pickup should generate about 1V AC
Make sure to "work" all connectors in/ out to feel for tightness and to scrub off corrosion. Inspect them with a light, and while you are at it, also take a run at the VR connector. The distributor connector is especially vulnerable as it has no real current flow.
If you can round up a .177 rifle cleaning brush--brass or stainless, they work for cleaning the VR connector, the dist and ECU connector and the flat trailer connector female terminals.
