Help with paint code
m99roadster
San Antonio, TX
I have a 1968 Dodge Dart 270 4 door and the PNT code on the fender tag says TT1 the trm code is H1F and UBS code is G. The body shop says the paint code is for Avocado Green Metallic im thinking it should be Medium Green Metallic. Were the Darts ever painted in Avocado Green? The door jams have been painted and it doesn't look right, can anyone help?
Avocado was the Plymouth name. Medium Green Metallic is the Dodge name. It was called Meadow Green Metallic on the Chryslers & Imperials.
Same paint, different names.
I'm sure this correct. I just couldn't find the cross-reference as quick as you guys could.
Thanks for all the info. I guess if all the colors are the same paint code it must be the correct color. It looks light compared to what was on it.
