Help With part number for water pump
RoadRunner1970
Active Member
PA
I was looking for a water pump for a 1970 roadrunner 4 speed with a 440-6 engine. Can anyone verify what is the correct part number for this vehicle? Also looking for a correct alternator part number. Thanks Brian
If you are looking for Chrysler part numbers . Water pump # 2843290, Alternator #3438172, or 3438178 , depending on month.
Thanks alot, would you also know the Chrysler part number for the correct water pump housing? Brian
