68cudahemi
Active Member
- Joined
- Apr 13, 2008
- Messages
- 40
- Reaction score
- 0
Ok I have a 68 barracuda. I'm installing a 71 340. It's got the timing cover and aluminum water pump installed from previous owner. I'm wanting to install all my pulleys etc. the water pump pulley sticks way out further than the crank pulley. So I got the cast iron water pump and it has extra bolt holes on the outer portion on both sides. Does the 67,68 use a different timing cover????
