Here 3 of my Projects out of 9
muddog
post falls, id
The Black car started as a 75 now 72 318 4 speed, The Green one is 70 360 auto (new motor in pictures is my 360 im finishing up), and my Tan truck is an 83 318 4 speed swapping to a 440 3-4 weeks away waiting on machine shop then the 318 is going in black car, going to be a daily driver!!!!!!
#2
Put a solid mount on the driver side of that 440 going in the pickem'up. I had to replace a fan shroud first time I got on mine using the stock rubber mounts. The torque still flexes the frame but a steel mount controlled it enough on my truck (86 short box) This was with a mild built 440 and a OD truck 833. Hope this saves you the cost of a fan shroud.
By the way I have tortured my OD trans in this truck and it shows no signs of wear or breakage. 31" tall tire 9 1/4" sure grip. Added a few leafs also.
When you get that swap together you truck will feel light as a omni. have fun.
Forgot to mention that truck does look nice. I have been wanting to put those type mirrors on mine.
