TrailBeast
AKA Mopars4us on Youtube
I'm sure if I pull it the cause will be obvious and I'm fairly sure I know what it is, but lets take some guesses based on symptoms just for fun.
Rolling down the road in 3rd (any speed) and I have a noise that sounds like a wheel bearing going bad. (kind of a muffled clattery roar) like a dry bad bearing.
It is directly related to driveline or road speed (also like a wheel bearing)
Turn back and forth left and right, no change
Gets quieter when everything is warmed up but still there.
On throttle/off doesn't make any difference.
Drop to second, no difference.
Can't tell anything in first or reverse because the car isn't rolling fast enough.
Pop it neutral while rolling and the sound winds down and goes away completely.
At that point everything is smooth and quiet.
Back into any gear noise comes back immediately.
It is only there when rolling and in gear.
So what do you think?
