Stacked360
- Joined
- Mar 9, 2009
- Messages
- 195
- Reaction score
- 4
The Duster is done with it's 05' hemi and 09' 545RFE nestled between the frame rails, it runs and drives great...but...when I go to start it it cranks for half a second, stops for half a second, cranks again for half second, pauses half second, and then cranks normal and fires right up. I've spoken to Hotwire about the issue and I guess it's the split second when turning the key between run and start that causes the computer to lose power. SO, I've tried putting in a capacitor on the "run" circuit to the computer to try to "buffer" the power between the contacts in the ignition switch. It didn't really do anything.
Has anyone else had this same issue? if so, how have you dealt with it?
Thanks in advance.
Thanks in advance.
