high hp and combo for big blocks
earthmover
in the tire smoke
nc
ok lets hear some of those big block combo and the hp of them et would be nice if you have any...thanks mike:scratch:
500ci.
Solid cam - roller rockers
.572 - .280 (appx) on the cam
Edelbrock heads ported by Hensley
Edelbrock RPM manifold
BG 850 dp carb
TTI 2" headers
3000 stall on built 727
700+hp 670+tq
Can't get the car to hook up unless I feather it....only can run 255's out back.
Mop
My 71 Scamp 440, has the Edelbrock RPM package set up ( Heads, Intake and cam). With Schumacker headers. It was dyno at 500.9 HP. It will run 12 flat at 112 MPH with the mufflers on.
I built a 512 that made 726 / 648 on the dyno
come on now you can give us a little more then that..lol
i thought about the 512 400 low deck,with -1 heads t&d rockers 1.6 with a soild roller 731 with the rockers 400-2 intake with 4500 spacer source crank alum. big block chevy rods and some diamond pistons with about 13.1 comp,also alum. main caps and girlde to keep the bottom togeather ,727 with 8" 5600 or 9.5 5000 verta in my 70 duster with as much fiberglass as i can put on the car cage and ladder bars..:shock:would like to make 750 and be able to run 6.0/5.90 in the 1/8 mile...but still in the :book: right now so gotta make my mind up soon....be good if i could get the car down to about 25/2600lbs:thumblef:
i know it got to be more out there come on guys ..mike:silent:
I was gonna use two hampsters and mouse in mine but instead went big with two guine pigs and rat. Not sure what kind of power im making.
If you are going to run above pump gas comp, why not go higher? That & flow is where the HP is in a NA engine isent it?
500ci.
BG 850 dp carb
TTI 2" headers
700+hp 670+tq
Mop
Dude your barracuda is badass, one of the top five cars on this site IMHO.
:notworth:higher comp. is a option . but we'll have to see just how far to push this thing..mike
Not sure on HP numbers but ran 11.07 at 121mph through the mufflers last year. 499 ci with 373 gears. cuda weighs 3250.
I just finished a 71 dart with 512 stroker 40over, Lunati 636 lift roller cam, Harland Sharp rockers, Edelbrock 88cc heads with some porting,Edelbrock Super Victor intake, 1100cfm Pro systems carb. TTI headers with 3.5 inch exhaust, 5500 turbo action convertor, 8 3/4 with 4.30 gears. I had 4.10 gears and ran a 6.68 at 105mph in the 1/8mile on fist shake down pass and broke spyder gears in the rear.
