Sean Stacey
Member
Just replaced vacuum booster on my 74 Dart, old one was bad. My problem is, with the vacuum line hooked up to booster and no pressure on brake pedal the engine idle will increase about 200 rpm. Once pressure is applied, engine idle drops in rpm's. Would the correct push rod length have anything to do with this? I am running a bigger cam 282 dur/ .491 lift and about 15 on the vacuum gauge at 900 rpm. Any thoughts? Might just switch and get rid of the booster all together. Sean
