HO Alternator(s) choices
rtee007
Deplorable Texan
Baytown, Texas
Yes the wiring has been upgraded and I have need for the extra juice. The current 60 amp unit is holding it's own, but after the dual fans are added I will need a bit more.
Anyone tried this one?
http://www.oreillyauto.com/site/c/detail/ULT0/010036.oap?ck=Search_01-0036_-1_-1&keyword=01-0036
Another possibility......
http://www.ebay.com/itm/360451491698?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
Another I looked at.........
http://www.ebay.com/itm/250995993147?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I would like to suggest you do a "search" of "overheating" in the Cooling Forum,, .. It was a while ago,, but I felt there was a trend , and I found that 10 of the latest 12 threads were folks with electric fans wondering why they overheat,, some got bigger fans but ended back with the original fans..
This was last spring to summer,..might want to check it out and save some headaches..
hope it helps
No overheating issues, just wanted to add the dual fan set up, thanks.
hope it helps
