HOG *** CAM
I have one of those that's the two barrel version. They are a two piece manifold that Chrysler heli arced together. They had problems with some leaking and those were replaced under warranty. Going over them with a flap wheel and then some epoxy primer and paint will seal them right up. I prefer the aluminum ones because they shed a good bit of weight from their iron counterparts.
Looks like the welder ran out of gas . But just kept on welding. :realcrazy::elmer:
I have for sale 1 Big *** HOGASS CAM. This one I believe is full race. And if you look closely you can see the Dots are lined up.
Asking $5000 + shipping.
Shipped from my house to yours.
Hope this is in the correct forum !
Bitcoin or Monoply Money only
Is that the super rare and hard to find 384 duration cam?
UPDATE!
Never mind, I found one.
I don't see any penstar on this one.
I've never seen a pentastar on any of um but then I've not looked hard either. It's factory though cause there's the casting number right on the intake. That'll probably get you in the ball park if you look it up .
'78ish to '83ish. Chrysler Engineering paper on this intake is here.
The bent-lookin' №-4 runner is supposed to be that way. It was made that way on the EB-welded aluminum 1bbl and 2bbl intakes on purpose to fix a longstanding tendency of the slant-6 to run rich on certain cylinders due to complex vagaries of flow out of the plenum and into the runners. Engines equipped with the EB-welded manifold show better cylinder-to-cylinder mixture balance.
These manifolds might be ugly around the edges, but they're technically pretty cool, they weigh almost nothing, and they work well if they're not floor-cracked, if the welds aren't porous, and if the gasket surfaces are all nice and flat. The floor cracks are easy to understand; thin aluminum isn't as heat-tolerant as thick aluminum or thick cast iron, so over the years the extreme thermal cycling in the hotbox area of the floor of the plenum can cause cracks. Fortunately the cracks are also easy to spot by careful inspection after cleaning.
The gasket surfaces are easy to true up if necessary, same as you'd do with any intake manifold.
The weld bead porosity isn't as big an issue as it is sometimes made out to be. Those weld beads look ugly, but the pockets and holes don't go very deep; they're generally just on the surface. The porous ones pretty much no longer exist; most all of those were melted down as scrap many years ago.
Even in the unlikely event you happen to find a porous one, it's not difficult to fix/prevent vacuum leakage. There are several techniques; some of them are described and pictured here. Another good method is to have the manifold powder-coated. Or you can clean the manifold thoroughly, put it in the oven til it's up to 200 degrees or so, remove it and quickly put a bead of a good aluminum RTV (I like Valco aluminum all-in-one applied with the help of their clever Tube Grip) to the entire weld bead, smooth the RTV firmly into the weld bead surface with a finger (don't burn yourself), then refrigerate the intake. As the metal cools it will draw the RTV into the air pockets on the surface of the weld bead.
