[SOLD] Holley 600 CFM 4160 Carb
fnaramore
POWEEERRRRRR
Fairfax, VA
Rating - 0%
0   0   0
Holley 600 CFM carb (Part #80457). In really good condition and was functioning properly when pulled off of car. Has electronic choke and vacuum secondaries. $200+shipping
  • Performance upgrade for stock to mildly modified vehicles
  • Universal calibration for easy bolt-on performance
  • Factory preset electric choke for easy startups
  • Vacuum secondaries for use on wide variety of vehicles. Compensate for all vehicle weights, gearing & transmissions to allow smooth opening of secondaries.
  • Single feed fuel inlet for easy installation
  • Compatible with GM, Chrysler, and Ford A/T kickdown linkage. Additional parts may be required.
  • Power valve blow-out protection
Also have a big block timing cover, small block original intake manifold with carter carb and a small block original distributor.
