Holley 600 Jets (318)
73Swinger18
Camarillo, CA
I just installed a secondary metering block on my Holley 4160. I'm now waiting on a handful of jets to be delivered. I would appreciate anyone who has a Holley 600 mounted to a 318 to provide me what primary/secondary jet combination worked best for them. Holley tech support recommended 60/64 with the standard secondary spring. Thanks!
That would depend on the engine combo.
I'm guessing if the Holley folks recommended that combo, they probably asked all the pertinent questions. So then I would be foolish to contradict them.
I must say however, that those jet sizes seem a little small to me.
I agree with AJ. The stock primary jet on an 1850 in the 64-66 range, so if that's what you have, a 60 will be pretty lean. I once searched for metering plate/jet size comparisons once, and I believe an 1850's secondary metering plate was in the range of a 57 or something like that. I'd want to double check to be sure.
Got Headers and Duals?
Got bumped up compression?
Got a dualplane?
Got a light A-body? SBM-A's vary between about 2800 to 3600 with driver.
Got at least 3.55s?
Got a 2800TC?
Got a 223* or bigger cam?
Is you at 1000ft or less?
I'd start with 61/67s and, add 1/2size jet for each yes, round up when req'd
Eg; 6 yeses = plus threes= 64/70
Jet up/down, as required
I'd block the secondaries closed and get the front dialed in first.
But before doing anything I would ballpark the ignition.
I made this up just now, just so you know, but I think it's pretty close
