JD Erisman
Holley Street Avenger 670cfm, Holley part number 0-83670. It has between 1,000 and 1,500 miles on it. The only changes I have made to it are jets, discharge nozzle, and power valve. It has electric choke, quick change vacuum secondary spring cap, glass fuel level sights, dual fuel inlets, and polished aluminum finish. I haven’t drilled it or made any permanent modifications. It’s not damaged, broken etc.. I bought it new about 4 years ago, the date stamp says 2014, if I understand it correctly, but I haven’t owned it that long. It comes with the Chrysler throttle lever extension, Moroso 1” phenolic plastic riser, and two Quick Fuel gaskets. Very good condition overall, everything works. $225 shipped anywhere in USA.
