fishy68
Tyr Fryr's Inc.
SOLD!! Freshly rebuilt Holley list 4781-5 double pumper. I used reusable non-stick type gaskets throughout so if want to take it apart to re-jet it it'll come apart real easy. Stock jetting and PV. High flow needle and seats. 30 cc primary and 50 cc secondary accelerator pumps with a high flow pump discharge screw on the secondary side. 4 corner idle adjustments. It has Duracon floats and I used alcohol compatible pump diaphragms so it will stand up to today's crappy ethanol infested fuel. It has down leg boosters. I replaced the base with a new billet piece as the original got cracked in shipment to me.
The finish is real nice. Looks like it has never been used much. It also has a -8 Russell braided fuel line that is capable of front fuel inlet or rear fuel inlet by just moving the cap. I installed it on my car and set the floats and took it for a quick test drive to make sure it ran right and it ran fantastic. I'd love to keep it but I'm sure if I did I'd be needing new back tires in nothing flat, LOL :mrgreen:
$325 plus shipping. Right now the carb is on sale at Summit and JEGS yet it'll still cost $550+ with the Russell -8 fuel line. You can save over $200 here and I'll stand behind it working correctly. Racer's or you guys with big cube engines that need a great 850 here it is.
I will also include a new air horn gasket and new reusable non-stick base gasket.
It'll fit into a large flat rate box that ships for $19 anywhere in the USA and will be insured for the full amount. Or you can the cost of shipping and pick it up at my location in central IL approx. 45 miles NE of St. Louis MO
PM me if interested
Sold!!
Thanks Louis
PM me if interested
Sold!!
Thanks Louis
