dgc333
I recently swapped out the Holley 4160 series 600 cfm carb on my 360 to a 4160 series #3310-2 750 cfm carb. The 750 works quite well and I definately have a bunch more top end but I get quite a bog when I step on the gas which I didn't have with the 600. I figured that I need to work on the accelerator pump some so I ordered the cam kit and a couple of larger squiters.
The 3310 comes stock with a 0.025" squiter and the least agressive cam (white). Staturday afternoon I spent quite a bit of time swapping parts around but only made the bog worse. Going up from a 0.025 to a 0.031 then to a 0.035 squirter made the bog worse but when the engine caught it was much more violent. That is with the 0.025 squirter I would get the bog then the car would go. With the 0.035 squiter I would get the bog but it would then launch violently such that in first or second gear the tires would go up in smoke. The same thing would happen going more agressive with the cams but to a lesser extent.
I also tried various amounts of preload on the pump arm but that didn't seem to make much difference.
I am back to the white cam in the #1 position with the 0.025 squirter. It's annoying but liveable.
The one thing I notice different between the 600 and the 750 is the 600 has side hung bowls and uses a rubber flapper to allow fuel into the pump then close off the port when the pump arm moves. The 750 has a little ball bearing retained by a strap.
My question is has anyone ever experienced a problem with the ball bearing not reacting quickly enough so that the intial part of the pump stroke fuel is being allowed back into the bowl instead being directed to the squirter? The only thing I noticed playing with this on Saturday was the intial movement of the accelerator pump resulted in just a dribble out of the squirter then it became a strong stream. Squirters and pump cams and preload on the arm did not make any differnce with this. The 600 has a strong squirt as soon as the pump arm moves.
Also, I do not know the vintage of the 750 (got it used and refershed it with a quick kit) but do newer ones use the rubber bladder in place of the check ball? Seems that the bladder is a better design.
