RustyRatRod
Caput villa stultus
Yeah you need to limit total to 34-36.I’ll likely dial it back to 20 it was fighting the starter hot) but I’ll have 40 total then.
That is something to think about. It would remove the need to limit total mechanical advance which I would need to do with 20 or 25 degrees of initial. I did unintentionally have it hooked up to manifold vacuum and it ran ok. Is the vacuum the same as ported once the blades open?Mean,
My GTO left the showroom floor with 26* initial timing. 6* init + 20* added from man vac adv. Small factory cam 197 @050 10.75:1 CR. So 25* does not surprise me. My engine has a smooth idle in gear, 800 rpm, & 48* at idle. Yes, 48*, not a misprint!
The best way to get the extra idle timing is with an ADJUSTABLE vac adv unit connected to man vacuum [ MVA ]. MVA is mentioned in the Edel owners book.
If you use 12* init, you can add 23-24* with MVA. You will likely need to make a stop for the VA actuator, but this is what hot rodding is all about....
idle rpm is often 100-300 rpm higher when I get back from a drive. Unplugging the vac advance (manifold) hose brings it down to where it is supposed to be.
I took it out, warmed it up and got 5 degrees no VA and 23 degrees total with manifold VA at idle. Obviously I don't have enough mechanical advance like this and I got some light hesitation on heavier acceleration. The distributor is a new Mancini unit with adjustable VA. Its still running fat at cruise and lean on heavy acceleration. Metering rod changes don't seem to be making significant changes and there is no combo of rods and jets that will address the issue so I'm going to try heavier springs and see if that moves things the right way. Manifold is only 10 -12 inches of vacuum at 700 rpm which concerns me. I had it up to 14 inches at one time somehow. At cruise its 15 inches. The idle rpm jumped 100 once it got hot. Tuning sure has been problematic as there is some issue I don't yet understand. If I don't get it sorted before the temps drop and the snow flies I will pull the distributor this winter.Mean.
Considering the combo, 25* at idle, as you have discovered is ideal, & about what I would expect with years of experience doing this.....
Idle rpm varying. Make sure the VA plate inside the dist moves freely. Is it an adj VA unit? Also make sure the centri weights move freely. The VA can have 25-30* of advance. How did you get 25* for idle? Combination of init +MVA?
How much idle vac now with 25* at idle?
I did a test drive with it set-up that way a few days ago. It was fine cruising. Today I am going to check fuel pressure as I am wondering if it is too high. (Carter mechanical pump)...Try this, it is simple. Disconnect & plug the VA. Adjust timing [ turn dist ] for ~25* of timing [ so engine will have 25* initial timing ]. Re-adjust idle mixture screws. Test drive; you may get pinging for this test, that is ok.
