This 140 GPH Holley Black Electric Fuel Pump part #12-815-1 which is for Street/Strip Carbureted Applications. It is also compatible with gas, alcohol or methanol.
• Lower housing casting designed for enhanced fuel flow and quiet operation
• Improved design for street/strip applications
• Compatible with alcohol or methanol fuels
• Flows 140 GPH (free flow)
• Flows 120 GPH at 9 psi
• Maximum pressure is 14 psi
• 3/8” NPT inlet and outlet ports – includes NPT to AN adapters
• Fuel pressure regulator is required (recommend Holley P/N 12-704 for gasoline & P/N 12-707 for alcohol)
• Motor draws only 4 amps current
• 7 1/2 amp fuse recommended
• Provides constant fuel flow with no pulsation
• Has externally accessible pressure relief valve (max 14 psi)
• Rotor/vane pump design is more tolerant of contaminated fuels
• Weighs only 3 lbs
• Includes mounting bracket for both pump and filter
Has less than 500 miles on it. Replaced because went to an EFI system
Retails with all parts for over $200.00
$140.00 or best offer plus shipping
Also selling a Jaz 20 Gallon fuel Cell with 90 Ohm sender
• Weighs only 3 lbs
