Holley Carb trouble
Eric_S68
Palm Bay, FL
Hey all. I have a holley 3310 (750 vac secs) brand new out of the box on my 360. Today, while running the car it wouldnt idle and I noticed that fuel was dribbling down from the secondaries. What could cause this? Do I have a stuck/misadjusted float on the secondary side? Running 6.5-7 lbs fuel press.
As allways, Your help is appreciated. Eric
Chuck's right,
Pull the rear float bowl and check it out. Something may have gotten bent due to rough handling by whoever it was shipped by as well.
Thanks guys, I was pretty sure it was a float or needle/seat issue. I figured I'd ask before tearing into it, since it's a new carb, fuel lines,pump, Fuel cell. Must have some debris caught in the needle seat area. I'll try a light tap with a hammer 1st. Then take it apart n see what lurks inside.
