holley carb
getting ready to buy carbs 572 hemi in 68 dart 3.73 gears auto heads flow 380 at 600 lift running 620 lift intake 600 lift ext 112 lobe lsa 266 and 272 dur at 050 fairly mild cam solid roller was going to use 770 vacum cross ram is there better carbs for this street car thanks for any input
Excellent choice. Make sure you tailor your power valve opening with the amount of engine vacuum you have at idle.
