Attention everybody go by yourself what's called a headlight amplifier and wire it in between the switch and the headlights.
It will almost double the brightness of your stock wagners...
This concludes the announcement ....[/QUOTE]
Ok, got it. It is technically not an amplifier, it is a relay device with the same function as what Crackedback sells.
Mine is older...and tired looking. Heres the newer version. Its the size of a regulator but taller. There's also a relay kit you can buy from a member here a couple different ways to do it I like the little black box when I had the car rewired the guy put that in there for me and I much appreciate it at night when I can finally see LOL
