[SOLD] Holley Sniper 4150 black
rmchrgr
Skate And Destroy
Stamford, CT
Up for sale is a brand-new Holley Sniper 4150 Stealth EFI system in black finish.
https://www.holley.com/products/fue...th_4150/sniper_efi_stealth_4150/parts/550-871
This system was purchased last year and is essentially unused. It has not had any fuel run through it. At one point it was taken out of the box, placed onto the intake manifold to check wire location and fitment and was then put back into the box. Nothing in the kit was altered from stock or even installed in any sort of permanent manner.
Comes as pictured including the main throttle body/ECU, main wiring harness, auxiliary harness, 3.5" LCD monitor screen, coolant temp sensor and whatever else comes in the kit linked above.
Be aware, this is only the throttle body so you will need to source your own fuel and ignition systems and whatever else that would be required to get this system running for your particular application.
Cool thing about this particular "Stealth" setup is that it looks like a 4150 carb. and fits under your garden-variety 5 1/8" opening air cleaner. Most people have no clue that you're running EFI unless you tell them.
Asking $1,200 + shipping. Currently, these particular systems are almost $1,300 from the usual places, including directly from Holley. Save yourself a couple bucks! Parts located in Stamford, CT.
PM with questions. If you're interested, send a zip code and I will estimate shipping cost.
Thanks,
- Greg
