Holley sniper and hyper spark distributor
Cardinge72
72duster340
Lac la biche alberta
Just installed the sniper efi and hyper spark distributor. What should my timing be set at? I’ve researched a few sites and videos they all say it should be set at 15* I’ve set mine to that and it pings and back fires WOT timing is set to 36* any one install this set up. What should I be using for timing settings
Did you follow the instructions to the t to install the distributor? If you have it clocked wrong, the computer cannot tell where you start from.
