Dumpsterpat
SOLD SOLD SOLD-$1200- For sale is a Holley super sniper fuel injection system part# 550-513 and the hyperspark ignitinion box, coil and distributor to go with it. The distributor is Holley #565-306 for a 426/440. The ignition box is #565-151 and the coil is #556-152. I still have everything that came with it down to the 02 sensor & including harnesses. Nothing has been altered. It works flawlessly and allows you to control fueling and timing very easily. I ran a trans brake off the incorporated 2 step and it works great. Very easy to set up and use and will eliminate all of your external boxes and controllers. It will even control progressive nitrous or blow through boost. Selling because I had lifter failure and it ate my cam. Going to a newer hemi I've been building. I can deliver to the Nats in Columbus Ohio this weekend. Thanks so much pm for pics.
