homemade electric car
SuperStock
Northern Virginia
Put 24 pack of 12V 400AH on floor pan, wires 2 each in series and each 12 in parallel, that make 24V at 4800AH. Direct a 24V 12000W motor to rear wheel. The power source of 4800AH will able to supply 500 amps to the motor for 9.6h drive. That approximately 500 miles per charge.
Im not worry sitting on a whole pack of electrochemical cells, in which chemical reaction continuous occur but do need to test them under extreme condition such as the floor hit by large object. I don't think it will ignite/explode but safety must ensure before commercialize to market. Its here:
Yet, its max speed is 60mph. Actualy it able reach 200mph but because the Law speed limit is 60 mph, so I add a resistor to reduce volatge.
imadeEV1 — Postimage.org
imadeEV — Postimage.org
